Under what conditions is the "Surplus Energy" logic triggered?
Two conditions must be met simultaneously:
① The energy storage battery is fully charged or no battery is installed;
② The solar surplus power exceeds 100W continuously for 5 minutes.
Related Articles
What is the maximum number of energy storage devices connectable to the Schuko sockets of the Zendure PowerHub 1P, and what specifications are required?
Up to 3 sets of energy storage devices can be connected, compatible with models such as 4000 Mix/AC+ and SF2400 Pro with grid-tie power ≤3680W.
What is the maximum number of energy storage devices connectable to the Schuko sockets of the Zendure PowerHub 3P, and what specifications are required?
Up to 3 sets of energy storage devices can be connected, compatible with models such as SolarFlow 4000 Mix Pro /AC+ and SolarFlow2400 Pro with grid-tie power ≤3680W.
What are the two connection methods for energy storage inverters supported by the Zendure PowerHub 3P, and their applicable scenarios?
There are two connection types: Schuko plug-and-play and hardwired. The Schuko method is for grid-tie inverters ≤3680W, while hardwired is for units >3680W.
What are the two connection methods for energy storage inverters supported by the Zendure PowerHub 1P, and their applicable scenarios?
Popular Articles
How to use Smart CT Mode
Recent Articles
