Important Checks Before Connecting PV Modules:
Before connecting PV modules, please verify the following items to ensure safe and stable operation of the unit:
  1. PV module specifications (e.g., open-circuit voltage Voc) are within the permissible operating range of the device.
  2. Each PV input (MPPT) is connected independently and not shared or mixed with other channels.
  3. All wiring polarity is correct (positive and negative connected properly).
  4. All terminal connections are securely fastened with no looseness or poor contact.
    • Related Articles
    • Important Checks Before Connecting PV Modules:
      Before connecting PV modules, please verify the following items to ensure safe and stable operation of the unit: PV module specifications (e.g., open-circuit voltage Voc) are within the permissible operating range of the device. Each PV input (MPPT) ...
    • What is the maximum PV input power that SolarFlow can support?
      SolarFlow supports up to 400W to PV1 and 400W to PV2 for up to 800W total PV input power, after Master 2.0.40 firmware update, it supports up to 500W to PV1 and 500W to PV2 for up to 1000W total PV input power
    • Can the SF2400 Pro be used without connecting PV panels?
      Yes. Even without a solar PV system, you can charge the storage battery via the grid. This allows you to take advantage of dynamic electricity pricing, charging during low-demand periods to reduce energy costs.
    • Popular Articles
    • Warranty Terms & Conditions (US)
    • How to use Smart CT Mode
