How to update to the latest AC firmware for your SuperBase V
PRODUCT:
SuperBase Pro 1500, SuperBase Pro 2000
  1. Connect your device to WiFi.
  2. Navigate to the firmware update section in your device settings.
  3. Select the option to update your AC firmware.
  4. Wait for the update to complete.
Please note that Bluetooth is currently not supported for firmware updates. Please connect your SBV to WiFi first.
    • Related Articles
    • SBV Unboxing Video
      PRODUCT: All SuperBase V
    • How do I fix an error code 004 on my SuperBase V?
      If see error code 004 on the SBV screen, please hold the power button for 15 seconds then let it go to reboot your SuperBase V. If you still see the same error code, please contact us at support@zendure.com for further assistance.
    • SBV的转化率
      产品规格: SuperBase V6400, SuperBase V4600 SBV6400:91.18% (2.8808KWh+2.99KWh)/6438KWh (额定容量)x 100% = 91.18% SBV4600 AC半载放电转化率:91.21% (2.1168KWh+2.079 KWh)/4600 KWh(额定容量)x 100% = 91.21%
    • How to setup the off-grid mode for the Zendure Home Panel
      Upon receiving your Home Panel, please follow the provided installation instructions. After installation, ensure that both the Home Panel and the SuperBase V are online, and update all firmware to the most recent version. There are two ways to enable ...
    • How do I choose a solar panel for my SuperBase V?
      Look for a solar panel whose open circuit voltage is below 150V, with a maximum output power of 3,000W.
    • Popular Articles
    • Warranty Terms & Conditions (US)
    • How to use Smart CT Mode
