How to unbind the vehicle?
1. Tap【Profile】, select the Tesla icon, and jump to the Tesla embedded page.
2. On the Tesla authorization page, tap 【Unbinding】 in the upper right corner to unbind the account.
Popular Articles
How to use Smart CT Mode
Recent Articles
