How to select PV panels?
Each independent MPPT input supports:
- Module rated power ≤ 660 W
- Short-circuit current (Isc) < 22.5 A
- Open-circuit voltage (Voc) ≤ 55 V
It is recommended that the total PV module power connected to each MPPT
does not exceed 1.5 times its rated power (approximately 1 kW) to balance
power generation efficiency and system stability under different weather conditions.
