How to Connect SuperBase V units with Zen Y cable
Zen Y cable can connect two SuperBase V units together for higher output up to 7200W. Then it can connect to a L14-30p power inlet for a regular transfer switch. Its a solution to replace fuel generators.
*It is only available for US version.
Steps
1. Turn off both SBVs.
2. Connect the communication cable to the communication ports of both SBVs.
3. Insert the Zen Y cable's TT-30P into the TT-30R socket of both SBVs, and connect the L14-30R to the L14-30P power inlet for a regular transfer switch.
4. Turn on the SBVs, and then turn on the AC output of either SBV.
5. When the connection is successful, the Y icon will appear on the screen.
