How should the device be stored?
For long-term storage, discharge the battery to 30% and charge it to 60%
every 3 months. If the battery level is below 1% after use, charge it to 60%
before storage. Keeping the battery at a low charge for extended periods
may cause irreversible damage and shorten battery life.
    • Popular Articles
    • Warranty Terms & Conditions (US)
    • How to use Smart CT Mode
