How many high-voltage power outlet ports does the Zendure PowerHub 3P have?
There are 3 high-voltage cable glands. From right to left: grid outlet port, inverter inlet port, and grid inlet/outlet port. After wiring, tighten all connections to ensure IP54 ingress protection.
Notes:
1. Grid AC input/output cable (three-phase system): Outdoor 5-core copper cable with conductor cross-sectional area ≤16mm².
2. Inverter AC input cable: Outdoor 3-core copper cable with conductor cross-sectional area ≤16mm².
    • Popular Articles
    • Warranty Terms & Conditions (US)
    • How to use Smart CT Mode
