How does the non-plug-and-charge function of EVFlow AC perform safety authentication and charging initiation?
In Non-Plug & Play mode, the system does not automatically close the relay after plugging in. Charging must be authorized via a local RFID card swipe or triggered through the mobile App either in close proximity (Bluetooth) or remotely (Wi-Fi/Ethernet via MQTT). Once account credentials are confirmed, the internal relay closes to supply power. When the vehicle is fully charged, the relay automatically disconnects power output. If you need to disconnect the charging cable, stop charging via an RFID card swipe or through the App first; hot-unplugging during active charging is not supported.
Related Articles
Which charging authentication/start modes does EVFlow AC support?
It supports Plug & Play (charging starts immediately upon plugging in) and Non-Plug & Play (charging requires external authentication via RFID card, Cloud, or the App).
What is the start and stop logic of the plug-and-charge function of EVFlow AC?
In Non-Plug & Play mode, the system does not automatically close the relay after plugging in. Charging must be authorized via a local RFID card swipe or triggered through the mobile App either in close proximity (Bluetooth) or remotely ...
Which charging start verification modes does EVFlow AC support?
Can EVFlow AC charge my vehicle during a power outage?
EVFlow AC does not store energy and cannot charge independently when its power supply is unavailable. However, when connected to a compatible solar and energy storage system with off-grid power capability and properly configured backup power, EVFlow ...
Which vehicles are compatible with EVFlow AC?
EVFlow AC is compatible with battery electric vehicles (BEVs) and plug-in hybrid electric vehicles (PHEVs) that support Type 2 AC charging. Before purchasing, please check your vehicle’s charging connector, supported AC charging power, and phase ...
Popular Articles
How to use Smart CT Mode
Why is my Hub’s battery light(AB1000 LED) turned off even though I have a battery connected to it?
Check the battery status page of the Zendure App to see if all your connected batteries are recognized by the system. If no batteries are recognized, please contact support@zendure.com for further assistance. Please include a picture of the Zendure ...
Recent Articles
EVFlow AC Installation Official Tutorial Video
EVFlow AC Official Video installation link: https://www.youtube.com/watch?v=QQ4JOUNW-30
What is EVFlow AC?
EVFlow AC is a smart AC home EV charger provide 3 versions (7.4 kW, 11 kW, and 22 kW) When integrated with Zendure HEMS 2.0,it coordinates solar power, home energy storage, electricity tariffs, and household load management to optimize EV charging.
How should I clean and maintain EVFlow AC
Inspect the charger, charging cable, and connectors for wear or damage approximately every six months. Before cleaning, disconnect the upstream power supply. Use a soft, slightly damp cloth to clean the enclosure. Do not use high-pressure water jets, ...
What should I do if charging does not start after plugging in the connector or the red fault indicator appears?
First, check the following: Ensure the charging connector is fully inserted. Confirm that charging authorization has been completed. Check whether the vehicle or Zendure App has an active charging schedule limit. Verify that the selected charging ...
How can I identify the device status from the indicator light?
Under normal operating conditions, green indicates online status, while blue indicates offline status. A solid light indicates standby mode, while a breathing light indicates that charging is in progress. When the breathing light changes to a solid ...
