How do I choose the right solar panels for SolarFlow 800 Pro 2?
Each MPPT input supports a maximum power of 660W, with an open circuit voltage (Voc) below 55V. Since solar panel output can vary significantly depending on weather conditions, it is recommended to connect solar panels with a power rating up to 1.5 times the MPPT's nominal power to ensure optimal performance.
