How can I identify the device status from the indicator light?
​Under normal operating conditions, green indicates online status, while blue indicates offline status.
A solid light indicates standby mode, while a breathing light indicates that charging is in progress.
When the breathing light changes to a solid light, charging is paused.
Yellow indicates a firmware update, while flashing red indicates a fault.
A blue offline indicator does not necessarily mean there is a charging hardware fault.
