Can the AC off-grid port be connected to a fuel generator?
NO. The AC off-grid port is only for supplying power to loads.
Do not connect a fuel/diesel/gasoline generator or any grid-mimicking power source,
as this may damage the device or pose a safety risk.
Popular Articles
How to use Smart CT Mode
Recent Articles
