Can I install SolarFlow 800 Pro 2 myself?
Yes, SolarFlow 800 Pro 2’s plug-and-play design makes installation easy for users.
    • Related Articles
    • SolarFlow 2400 Pro Installation Manual
      Video link: EN: https://www.youtube.com/watch?v=X307oOWnYZI DE: https://www.youtube.com/watch?v=7qATOYRR6Bc FR: https://www.youtube.com/watch?v=N3cQ1WDFSI0 NL: https://www.youtube.com/watch?v=PAbmGMwHOh8
    • How to use Smart CT Mode
    • SolarFlow 1600 AC+ Installation Manual
      Video Link: FR:Installation complète du SolarFlow 1600 AC+ : du déballage au mode hors réseau - YouTube NL:SolarFlow 1600 AC+: volledige installatie – van het uitpakken tot de off-grid-modus EN: https://www.youtube.com/watch?v=e1HQqSp9tnw DE: ...
    • How does the Zendure PowerHub 1P enable whole-home off-grid backup on the main line?
      In a single-phase power system, install the PowerHub after the main switch in the distribution panel so that all household power passes through it. Install a new breaker after the PowerHub with a rated current ≤ the maximum circuit capacity to ...
    • What is the difference between SolarFlow 800 Pro and SolarFlow 800 Pro 2?
      The only difference between the two versions is appearance and physical size — the SolarFlow 800 Pro 2 is more compact. There is no essential difference in structural strength or protection rating between the two models.
    • Popular Articles
    • Warranty Terms & Conditions (US)
